WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
There is litterally fewer thing I enjoy less than running a saw. This was my favorite saw and honestly the only saw I have purchased. The rest I've used where either my father or father in-laws, uncles and so forth. Husqvarna, Sthil, Homelite,Poulan.....I've ran and used them all and some brands I've forgot.
Ran some older gas this day....done before. Ran a little under power lower octane as expected. Swapped to my new fun bar and chain. Dumped the old gas for 100 percent gas and the mix I've used off and on. (never been completely loyal to echo mix) often ran the Red bottles from Lowes. "Pro Mix". This occured somewhere between a tank to tank and a half through the new mix. I was never really burning a whole tank. Stopped for water and retensioned new chain and topped off the tank.
The saw didn't see huge action last year but I've cleaned up and cleared stuff all through fall and spring on and off. So easily a month's or two between used but not shelved for extended times.
Pre work routine was as usually. Clean filter, file, fill, fire. Saw has never needed anything else.
So the failure.... What caused it?
Bunch of guys on here have alot better knowledge than I have on diagnosing combustion engine failure. A buddy and long time 2 stroke fan and racer feels like it was purely lack of lubrication. Industrial saw less than industrial quality oil. He also wants me to rule out crank case leaking.
Any of you guys seen this first hand?
Definately will check the case before a new top end. No sense killing a expensive replacement for bad seals. I just wanna prevent the buzz kill from happening again.
