- Mar 13, 2005
- Raleigh, NC
I was wrong. I bought it in 12/21. No warranty.Sounds like a warranty at least. Aren’t those 3 years?
Agm won’t corrode, that’s worth its weight in gold for me as I have so much stuff that sits around. Corrosion travels too and kills wiringLots of folks run only and promote only AGMs these days.
There is at least an intelligent debate and discussion over whether that's ideal. However ...deep cycle batts as cranking batts will unquestionably have shorter life cycles..
Do you use die-electric grease on your DC connections? The only AGM I am using now is in a ATV. Everything else is regular batteries wet cell, and I do use die-electric grease on the connections, and zero corrosion issues.Agm won’t corrode, that’s worth its weight in gold for me as I have so much stuff that sits around. Corrosion travels too and kills wiring
Ummm….Agm won’t corrode, that’s worth its weight in gold for me as I have so much stuff that sits around. Corrosion travels too and kills wiring
only AGMs these
Don’t the AGMs corrode the terminals less because they don’t vent? All my AGMs have not had any corrosion, while I have to clean the corrosion off the terminals whenever I change out a conventional, plus clean the mess off the battery hold down and trayAGM has the same acid just soaked into a fiberglass mat…
If a loose connection it will corrode and oxidize just the same.
Almost like they were both made by 1 of the 3 battery manufacturers. I get a heck of a deal through O’Reilly and can get them cheaper than Walmart prices. So I go that route. Plus they save to your number at parts houses. Walmart, you better have that receiptView attachment 431857
The one on the top costs $180 and has a four year warranty. The one on the bottom is $270 and has a three year warranty. Otherwise identical, same reserve capacity, etc.
Man Walmart ain’t that bad, it’s like tsc and hf. You go in and come out with 50 things you didn’t know you neededSlightly less warranty but you don’t have to go into a Walmart![]()
Yeah, good point. If I bought that one, I'd be shelling out $180 at month 37 when it suddenly decided to (intermittently) become a five cell battery. Totally worth it.Slightly less warranty but you don’t have to go into a Walmart![]()
I think it’s the people there lolYeah, good point. If I bought that one, I'd be shelling out $180 at month 37 when it suddenly decided to (intermittently) become a five cell battery. Totally worth it.
Walmart is the place to buy oil, filters, and batteries. No membership fees, either
That's my point. But people like to go "ew, Walmart yucky".
Don’t feel bad. @Chris_Keziah got me having to buy batteries for my dodge. His 2016 ones are going out lolFucking Walmart battery bit the dust. The charger has been trying to pick it up all day, but it's still at 10 volts. Junk.
I have that same charger and it has done some good work.Fucking Walmart battery bit the dust. The charger has been trying to pick it up all day, but it's still at 10 volts. Junk.
Same. It's my favorite.I have that same charger and it has done some good work.
Same!Same. It's my favorite.
