toyota1
- Apr 17, 2008
- Fort Mill, SC
Could sombody with a 22re tell me where the coolant hose on the tstat housing goes? Its a 3/8" line i think.
I mean the smaller line kindof off the side that nasty looking hole in the picture is where the thermostat sitsStraight to the top of the radiator, pretty sure at least I'd have to go outside and look. The diameter is 1 1/2", you sure about the hose?
Yep, IAC/TB are more accurate names than the Air Intake, thanks for the clarificationThat goes to the IACV on the bottom of the TB. That hose looks kinda like a P.
.im running propane with an efi manifoldUnless you are changing over from EFI/carb to propane, you will need it. The IAC valve on the TB must have the coolant running thru it to operate. Otherwise you will be getting too much air thru the TB to run after the engine warms up.
Ive been looking into getting rid of this, all i need is a throttle blade to open and close haha ill have some time tommorow to work on it if i get my other stuff doneGotcha.
Just some tech...
One of the larger ports inside the TB goes into the IACV. When the coolant temp is low, the IACV allows air to bypass the throttle valve. In conjunction with the IACV and the cold start injector, the engine will idle faster until it warms up. When the engine reaches temp, the IACV closes and the computer turns off the cold start injector. If the IACV is not operating properly, the engine wont get enough air or it will get too much air.
Thanks for the help, i try avoid early styles of fuel injection so i dont know to much about them. Im trying to make this setup as simple as possibleGotcha, just trying to help you avoid a huge vac leak.
