CasterTroy
Faster'N You
- Mar 21, 2005
- Wallburg
All this fear mongering created by someone who has never run a 3link, and hasn't wheeled hard enough to break anything in a decade
Granted, as said, I beat the piss outta that rig and have a ton of (2nd place) trophies to show for it. If I was heart set on a crossmember mounted tower, it would be gusseted 6 ways to Sunday and frenched into the tube.
Have you considered golf?If you ask the wrong questions, you're going to come to irrelevant conclusions.
The benefit of a 3-link is that it's cheaper than a 4-link, so it's a decent budget option. They also have packaging benefits in certain applications (again, that is often driven by cost/benefit). The downside is that when they fail, they do so catastrophically. We wheel with our kids, so catastrophic failure isn't an option. We had a guy in our group on Fins & Things lose a front upper. It took out both coilover shafts, the oil pan, and the driveshaft. We spent all morning cobbling it back together just so he could spend about a grand with an off-road tow truck company. His "once in a lifetime" trip was ruined on day one because he wanted to save a couple hundred bucks on an upper link. Cyd still thinks Fins & Things is a shitty trail. I imagine this has something to do with it.
3-links also don't behave symmetrically, but that's something few people notice.
If you have a TJ with a stock drivetrain, a 4-link doesn't have any link clearance issues other than the motor mounts (and that's easily addressed). With stock short arms, a TJ front axle will travel more than the drag link will allow, and will eat up everything a 14" shock has to offer. Is it usable travel with the links drooped 30* relative to the chassis? Probably not, but the notion that short arms can't travel is just an internet rumor spread by people who have never looked into it themselves. And if short arms can move like that, what benefits does a 3-link bring?
It all comes back to priorities.
With a track bar, you need conventional steering to keep the geometry happy (trackbar and drag link moving in the same arc, at the same angle, with the same length) so that there is no bump steer, because the trackbar causes sideways motion when the suspension moves. With a triangulated 4 link, on the street, the suspension motion is primarily vertical, so the arc motion of a drag link actually will cause bump steer. So for a 4 link, full hydro is a good option.For a street driven rig with hydro assist, how is the best way to go about doing a front 4 link? Single (uppers) triangulated or dual?
Over the years and as more folks have dove into long road hauls with full hydro and the dialing in of such, that may be what I do.With a track bar, you need conventional steering to keep the geometry happy (trackball and drag link moving in the same arc, at the same angle, with the same length) so that there is no bump steer, because the trackbar causes sideways motion when the suspension moves. With a triangulated 4 link, on the street, the suspension motion is primarily vertical, so the arc motion of a drag link actually will cause bump steer. So for a 4 link, full hydro is a good option.
True. However, if I do go the extra mile to 4 link my front, I'd likely do so to ditch the track bar.A parallel 4link with trackbar would likely be the best setup to keep a steering box. Something similar to mid/long arms on a JK or Dodge/RAM/Ford truck.
Would that act different than radius arms?A parallel 4link with trackbar
Sure, but going back to the "budget" question... if you're talking TJ, if you add a bridge over the diff to raise the upper mount, that gets into the oil pan, so you have to lower the bump stops. For the cost of the bridge, upper mount, and bump adjustments, you could buy a passenger upper arm. Likewise for lowering the lowers by an inch. "That'll kill muh ground clearance, Clarence!" It reduces the likelihood of tearing the stock TJ frame, though.wouldn’t that fight the twisting/axle wrap forces that cause so much of an issue with a 3 link?
Think vector geometry. With radius arms, the forces in the axle all get resolved within the arm itself, then the arm acts on the chassis. With two links on each side, the upper and lower are each imparting forces on the chassis.Would that act different than radius arms?
so how many folks view getting their suspension setup after they complete all the supporting mods? Like a motor mount lift? Or rotating the steering box to allow you to stretch the front of a TJ to get the axle in front of the crankshaft? Because most folks forget all that sort of stuff in my opinion. Maybe I’m overthinking most the time and plan out things too much in advance to circumvent problems that can arise.Sure, but going back to the "budget" question... if you're talking TJ, if you add a bridge over the diff to raise the upper mount, that gets into the oil pan, so you have to lower the bump stops. For the cost of the bridge, upper mount, and bump adjustments, you could buy a passenger upper arm. Likewise for lowering the lowers by an inch. "That'll kill muh ground clearance, Clarence!" It reduces the likelihood of tearing the stock TJ frame, though.
Few people have checked to see if the drag link is limiting the travel of their front suspension. They just go on the internet and complain that "X" brand tie rod end is garbage.so how many folks view getting their suspension setup after they complete all the supporting mods? Like a motor mount lift? Or rotating the steering box to allow you to stretch the front of a TJ to get the axle in front of the crankshaft? Because most folks forget all that sort of stuff in my opinion. Maybe I’m overthinking most the time and plan out things too much in advance to circumvent problems that can arise.
Going to have to have a ridiculous drop pitman arm, pitman arm with modified rod end so the heim or TRE points at your knuckle, or put two minor bends in your drag link to relax the angles.Few people have checked to see if the drag link is limiting the travel of their front suspension. They just go on the internet and complain that "X" brand tie rod end is garbage.
Rod ends with misalignment bushings are capable of amazing things. Tie rod ends are not.Going to have to have a ridiculous drop pitman arm, pitman arm with modified rod end so the heim or TRE points at your knuckle, or put two minor bends in your drag link to relax the angles.
Can’t have it all. Full hydro really sounds like money when you start pondering steering with long travel suspension.
