rcassettyjr
New Member
- Jul 12, 2005
- Southport, NC
StudNuts said:Whats wrong with the ole 360/727/(Insert T/Case here)
Nothing is wrong with it other than they don't have a 727/(InsertT/Case here), they have a 3speed/D20. So I guess you are suggesting they go out and get a different tranny and TC that will require some (minor) fabrication to put in. I guess that is a lot different than when I suggested they go get a different tranny and TC that would bolt in without fabrication using readily available factory parts.
StudNuts said:You only get nickel and dimed to death when cheap bastards on the board here try and piece sub-par junk they have laying around together.
I would guess that's why we have both suggested them using a different tranny and TC. Re-using the stock parts that work as the engineers designed them is the same as sub-par junk? Funny, they worked fine in the nearly 30 year run of the SJ (except the ammeters - those did suck) I supposed you re-engineered all the parts when you did your swaps.
If they re-use as much as possible of the donor vehicle, they will be putting together parts that are meant to work together and not having to go out and buy them since they are already there. Somehow I guess it does not make sense to other people to use what you have laying around in your parts bins or donor vehicles instead of spending your allmighty dollars. Oh sorry, I forgot you guys have a money tree growing in your backyards. Watch out for the ice storm up there, your assets might be frozen.
You's definately gonna break now....haha
