3D PRINTING
Might be a dumb question but did you remove all of the packaging screws and foam etc that comes packed with?
Our H2D has operated flawlessly for a couple months and several spools of filament. Everything from complex multi color stuff to a Batman mask for a large dog. Once I get time I’m going to set up a window vent system and try some one piece pteg 1:10 RC crawler bodies. Need to try to make one for the slash too, that thing takes a beating.
Yeah, I haven't found any other packaging material inside.
Ultimately, I ended up splitting the model into separate parts rather than trying to print a bunch at once. That worked fine. I'm suspecting it was likely more of a model problem than a printer problem at this point.
So you don't have this problem with other models that are tall?
One other model had a similar issue in exactly the same place. I just completed a print for the poop chute discharge that was really tall and had no issues there, but it was to the back left of the plate rather than the front quarter.
The new Glacier plate seems to have made a difference, there's definitely more adhesion over the stock PEI. I think the Bambu filament overall works better too.
Some days my job is really frustrating.
Then there's moments like this
Thats SLA printed, it has several channels inside for sensors. Had to print top part separately and stick on w/ uncured resin to remove support and clean sensor channels
