BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
1998 TJ with 4.0, AX15, Rubi 4:1 tcase
This is a little long but I need some help with what is wrong with the 4.0.
For a long time I have had a problem with the jeep stalling when climbing anything in 4 high. Started back at Big Creek way back in the day trying to climb the huge hill: would be in 4 high and in 1st or 2nd, start hammering down going up the hill and then would lose my pedal (I could even have it to the floor and high RPMs) and engine stalls, and then takes a long time to crank but always re-cranks. This happened all the time on the trail in 4 high, so I stopped using 4 high, would have to run 4 low in 4th gear sometimes but never had a stalling problem.
Now this weekend at GER it started doing the same thing in 4 low and 1st gear. I will come up to an obstacle and start climbing it and then stalls even though I am still in the throttle.
Jeep takes a long time to crank and have to give it some throttle usually. Assuming that is related.
Give me all the thoughts.
I heard JK automatic transmission isn’t bad
