ponykilr
Guest
My friend Jeff has a 2003 6.0 with over 200K and never has had a bolt turned except for regular maintenance.
The horror stories are from hopped up trucks and/or guys who towed very heavy with lead feet.
The 6.0 only has 4 bolts around each cyl instead of the 5 in the 7.3.
They were already "hopped up" from the factory and had stretchy "torque to yield" head bolts.
So under heavy heavy load and high temps the head bolts stretch and the gaskets yield.
Get a clean used one and a scanner or gauges to keep the oil and coolant temps monitored.
What you are looking for is when oil and coolant temps get to over 12* or so difference, this will show you that the cooler is stopping up.
As long as they are close and you aren't WOT up Black Mountain pulling a huge load they will last a long time.
If the temps are 15* different, delete the cooler if you catch it early enough.
If you have the $, do studs and delete but keep the rest stock and they will last forever and make lots more power than a 7.3.
The auto trans with the 6.0s is worlds better than the 7.3 trans too.
