russ0943
yehaw x10
- Mar 28, 2007
- Valdese, NC
2000 F250 7.3L
I have an electrical gremlin somewhere. When I turn off the engine and remove the key, the radio will shut off...then it will cycle on and off in about 30 second intervals. The trailer brake controller will also stay on. I had one instance where the blower motor and AC clutch still had power after key off.
Door switch seems fine and dome light reacts to it.
Accessory Delay Relay under dash pulls in/out randomly after key off.
Heard sound from Engine-side fuse block that sounded like fast flickering once when problem started. Sounded like a relay pulling in/out really fast.
All fuse blocks are dry.
Engine starts and everything seems ok after it starts.
Thanks for any insight.
when the alternator is crapping out. Good luck though
