ol'Jeeps
Dirty Jeeps...Done Dirt Cheap!
- Dec 5, 2006
- Hickory, NC
Oh...and 99% of the answers will be right!
Preventative Maintenance!! I'm surprised yall don't know me by now but that's just what I do. For me and my piece of mind on 27yr old truck is knowing IF I brake down to or from a trip somewhere, it's gonna be something big that well, just goes. Besides, head gaskets and upper gaskets, water pump and tune up with some brake stuff isn't that costly at all when you do the work yourself. Power steering pump and rotors are the only things wrong but I love to drive and travel with knowing what I've done is reliable.Are all those parts and gaskets bad? I wouldnt replace all that just for the sake of it.
kinda true but, The large opening spacers are normally designed for single plane intake and the 4hole spacers or split spacers are designed for dual plane intakes and people do different configurations between the different intakes and spacers to get that rpm range the best all around performance...that's what I was wondering is all...then i figured maybe modify the center divider to help raise the rpm range a little with a certain spacer combo.The spacers have a large opening so that they are more universal, not nessecarily becuase they work better.
Your questions will be 95% answered there! (see attached pic...!) Def worth the $10
for m uses will be one healthy stout tow rig/work truck
Isn't it good though for the tow rig to be heavy? I was under impression heavier the better and more stable pulling..sure might have to add extra power but I was thinking extra weight of service bed was a good thing...You forgot "really heavy". Don't forget that.
Heavy tow rig does help with trailer sway and keeps the trailer from pushing the truck around as easy, but its not the extra weight to get moving (power as you say) thats the problem. Its the extra weight you have to stop. Every bit of extra weight on a tow rig is less weight you can legally carry in cargo before you are overloaded, going by state tag rating or manufacturer gvwr.Isn't it good though for the tow rig to be heavy? I was under impression heavier the better and more stable pulling..sure might have to add extra power but I was thinking extra weight of service bed was a good thing...
