89 YJ upgrades
89wrangler
Not a new member
Bostic,NC
finally started the upgrades on the YJ...Again :shaking:This round will be a front HPD60, chromo axles, 35 spline outers,5.13 gears, drive flanges along with a 3" inch stretch and 4 link rear with coilovers.
the D60
picture.php
picture.php
disassembled
picture.php
sandblasted
picture.php
Some of the goodies
picture.php
more goodies and a plug for ECGS
picture.php
Barnes4WD for brackets and joints
picture.php
axle seals
picture.php
Gears
picture.php
Lockright
picture.php
rebuilt knuckles and new studs
picture.php
hight steer arms w/tie rod behind axle
picture.php
removing a F250 HP44 with chromo's and ARB. Also going to step up to 42's
sweet jeep build. i'm building a hp44 and i HOPE i don't take it out. haha. gets pricey $$.
gets pricey $$.
Yea, I "thought" the D44 was expensive. Wait til you build your D60 (and you will):lol:
Should have my new axle joints from ECGS tomorrow. Picked up a new set of wheel bearing this evening. Paint and final assemble tomorrow. Then the jeep goes on to the lift to remove front and rear axles to start the rear link and stretch. March 31st deadline is rapidly approaching.
Won't the pressure of the rotating gear mass wear off the yellow paint though? And once you close it up no one will be able to see it. Seems like a waste of time to me.
Otherwise, looks like you are doing a fine job.
Also, you could have just bought The Krawler for about the same as what you put in your D60F and not had to do all the work :)
I was waiting for someone to post up about the gear pattern. I have not added oil yet.
Jon, I am way too far ($$) in the the red Jeep to turn back now :driver: Plus I really like the V8 rumble :lol:
More pics tomorrow
Front axle ready for hubs
rear axle out and frame brackets removed
rear axle brackets removed
rear bridge
Looking good Steve. Are you going to make your deadline?
Not looking good at this point. Will have a better idea after this weekend.
nice!!!
x2
what size tires were you running on that f250 d44?
39.5 Irok's with chromo shafts and ARB
Thanks for the compliments on the shop. :beer:
Made some more progress this weekend. Damn the 4 link calculator is kind of confusing. Got things figured out I think. I am making the uppers adjustable(3 inches) for the time being to see what happens as it appears moving the uppers makes a big difference in the AS figure. Once I figure out what works I will weld them up. Going to thread the upper links tomorrow and install them before I make things final. I also think I am going to move the lower links down on the axle once I get the shock on. Anyway...
axle mount
picture.php
[/IMG]
Frame mount
picture.php
Mocking up the uppers with PVC :lol:
picture.php
[/IMG]
Upper bracket started
picture.php
[/IMG]
Front axle ready for install
picture.php
Hope to get the rear links finalized tomorrow as well as the front axle installed so I can final dims si I caN get my Dshafts lengthened and shorten and back by Friday.
out with the old
picture.php
picture.php
In with the new
picture.php
picture.php
Got the upper tube tapped and mocked up ready to weld everything.
picture.php
Got the front done this evening except for fully welding the tube adapters. 1 1/2" .250 tube tie rod and drag link with 1 ton TREs and hydaulic assist
picture.php
picture.php
