9” rear drums locking - help!
Jeffncs
Wake Forest
Before I scrap the drums and spend $800 on a disc brake kit, can anyone offer insight on what may be going on with these brakes?
1977 bronco, 9” rear not original to truck. It’s a small bearing setup vs the stock big bearing. Everything is new on the brake system…. Master cylinder, distribution block, hard lines, soft lines, all brake components front and rear.
Front are stock disc brakes for the 77 D44
Rears are 10” drums that I pieced together since the axle only had a bearing retainer left when I got the truck.
Symptoms:
Test drives result in shoes dragging so bad that the drum temps are outside the IR thermometer temp range. I’ll take it all apart, reset everything and it will happen again.
Some add’l notes and thoughts as you ponder my issues….
I don’t typically adjust the brake shoes when putting them back together. Should I?
The shoes are getting displaced from the upper pin (see pics).
I’m missing the little football shaped plates on that same pin (no clue what they do!)
HELP?!?!? I’ve rebuilt brakes countless times and this is just absolutely stumping me!
IMG_2101.jpegIMG_2100.jpegIMG_1989.jpegIMG_1988.jpegIMG_1987.jpegIMG_1986.jpegIMG_1985.jpegIMG_1984.jpegIMG_1983.jpegIMG_1982.jpegIMG_1981.jpegIMG_1980.jpegIMG_1979.jpegIMG_1978.jpegIMG_1977.jpeg
Have you checked the adjustment on the rod going into the master cylinder if it’s too long and applying any little bit of pressure as heat builds it’ll apply the brakes harder and harder And of course, with shoes having so much surface, they show face a lot faster
Looks like the wheel cylinder pins have to much travel outward causing the shoe to lose it's seat when retracting.
Suggest to put it back together and adjust until you can hear the shoe barely touching the drum when rotating. Then back off the adjuster so it's not touching. Then give them a try.
Looks like your springs have little to no tension in them. The coils look to be almost touching each other. Especially the red spring. Dropping it down to the hole near the e-brake bar might help, but from the picture looks like it would be too much.
My guess is you have a springs for a larger shoe.
You need those "football" pieces, in combination with all the stuff latched over the pin they hold those shoes from slipping out of line. The front shoe lifts away from the pin when you first apply the brakes, it has to slide back into place when you let off of the brake. It appears that the shoe slips behind the pin boss and gets stuck. Make sure there isn't a ridge or anything for the shoe to get stuck on.
Looking at it again the problem may be with flat bar going from the e-brake arm to the front shoe. It looks like it's not letting the front shoe return all the way.
Try it without the flat bar and see how it works.
