Papa_Jon non speller Joined Jul 27, 2007 Location China Grove Oct 18, 2018 #26 So put motor back in jump ground wire to ground wire on blower it started spinning . Does this mean ibhave ground problems?
a_kelley mechanical fixer Joined Jan 26, 2010 Location Rutherfordton Oct 18, 2018 #27 Yes, check for ground at the black wire on the speed switch. If it's not less than 1.5 ohms to ground, splice that wire to ground &/or check the ground at the back right side of the dash.
Papa_Jon non speller Joined Jul 27, 2007 Location China Grove Oct 18, 2018 #28 Either i didn't see this or it happen just now these 2 burnt in 2 Attachments 15398901080934230988498295902130.jpg 70.1 KB · Views: 207
Papa_Jon non speller Joined Jul 27, 2007 Location China Grove Oct 18, 2018 #29 Quick fix for now to see if it works .. will soder and shrink them if all is good
Papa_Jon non speller Joined Jul 27, 2007 Location China Grove Oct 18, 2018 #30 Got its working but only through defroster. But hell im happy with that for heat . Speeds settings work also
a_kelley mechanical fixer Joined Jan 26, 2010 Location Rutherfordton Oct 18, 2018 #31 Check vacuum lines for vent selection
Papa_Jon non speller Joined Jul 27, 2007 Location China Grove Oct 18, 2018 #32 Sadie says its fine but i need to keep cat out of her jeep Attachments 15398908626228409076844728457471.jpg 67.8 KB · Views: 227
