ghost
- May 25, 2006
- Hartsville/Camden,SC
Glad I clicked in here. I learned about ORB fittings....
Nope.
It's an ORB. The seat is machined for an O-ring, where a straight would not.
info:
Connection Types: American Connections
There are many connection types all across the world. This post will help you identify and define common American connections.blog.brennaninc.com
Cliffs:What's interesting is....they can both seal with an o ring, washer, or a combination of the two and are both straight threads. Generally, you'd see NPS on something like electrical conduit and ORB on hydraulic stuff. I think the very in depth and technical difference is the actual threads themselves and the specs they're machined to.
Most of the ORB hyd fittings I've used had a convex washer above the o ring to help protect it or keep it from squishing out. NPS isn't usually used (from what I can see) in pressurized liquid applications. Maybe it is...not sure. All of the fittings I used on the equipment I've had were JIC, ORB, or ORFS. Sometimes an NPT, but not generally.
However, as far as I can tell, they're pretty much interchangeable between the same thread sizes, obviously.
Random ADHD hyperfocused nerd moment over
sae orb and npsm are different
where do I sign ?get rid of npt while we at it.
There are people around here who would do something like that, but I'm not naming names. I guess if you need to get your air shocks Fuller you do what you gotta do.
