another lesson learned the hard way
VortecJeep
Powered by Uranium-235
Concord, NC
When changing your own oil, make sure the rubber o-ring is still attached to the oil filter you are removing from your vehicle.
I changed mine over the weekend. Didn't look at the old filter, so I didn't know the o-ring had come off of the old filter and stuck to the jeep. I screwed the new filter on, poured in 6 qts of oil, cranked it up, and quickly blew 4 qts of 10W-30 all over the jeep and driveway because even though the new filter was tight, it didn't make a seal since the old o-ring was in the way.
Well, at least I always crank it up after an oil change instead of waiting until next time I drive it!
ah, fond memories, haha. i watched oil pressure rise, then fall..............wtf? cut it off. oh, there's a big puddle of oil.
dangit
havent we had this before?
lmao im glad it happens to people other then my employes.
double seal is one of the biggest claims in the lube bussines
I did a double gasket when I worked for a quick lube place, and it let go as i was standing under it I was covered in oil.. I learned that lesson. I always double check that surface before i put a filter on.
I always clean off and look at the area where the new gasket will seal. I also put a small amount of lube on the new gasket sealing surface before putting on the new filter. I thought everyone did this.
<><Fish
:shaking:At least you didnt forget the drain plug. Talk about feeling extra stupid that morning.
On a similar note, I was having trouble w/ my oil PSU reading, so I removed the stock sensor, and threaded in an aftermarket mechanical one.
Cranked it up - that's odd, no reading, turned off real quick.
oil everywhere.
I'd threaded the new sensor into the wrong hole in the block... turns out 22r has a few extras that are pre=threaded threaded but not completely tapped through. Doh!
Every time I saw that stain on the driveway I kicked myself a little.
Some guys I went to college with changed the oil in a car in the shop one time, forgot to put the drain plug in. Needless to say the instructor wasn't very happy about 6 quarts od syn. blend oil on the floor...
I witnessed that in HS auto shop too, that dude never lived that one down. I wouldnt have expected watching someone pour oil on the floor would be so funny :lol:
