burrellsjeep
Breaking Stuff...
- Nov 19, 2008
- Morganton NC
I have followed it from the first time he posted it,
Really different thought I would share.
Link to the Build
Current specs
111" wheelbase
88" wide
81" tall +24" adjustment
12" Belley Clearance +24"
4300 lbs 60% sprung 40% unsprung
170 HP 150 Ft/LBS Nissian 2.8L 6 Cylinder
Impco 225 propane mixer
Hyster air filter box
Toyota Carolla radiator and fan setup good for 245 HP
Thermal Transfer hydraulic oil cooler
Oil Cooler fan Crown Vic.
FL 70 steering gear
Auburn planetaries
Eaton drive motors
Sauer Sunstrand hydrostatic M46 tandem pump
Gates 6000 psi 3/4" hose
25 gal resevoir
50" x 14" tires on 28" rims
Top speed 22 MPH
Pumps Displacement 2.81 CI/REV
Pump Max REV 4000 RPM
Pump Max PSI 5000
Planetary Ratio 30:1 Rated @ 50,000 Inch/LBS
Drive Motor Displacement 2.48 CI/REV
Drive Motor Torque 156 FT/LBS
Planet Torque 4687 FT/LBS
Drive Motor Speed 4532 RPM
Planet Speed 151 RPM
Tread Speed 22
Draw Bar Pull 4686 LBS
One of the most interesting builds I have read, The guys is a genius.
Link to the Build
Current specs
111" wheelbase
88" wide
FL 70 steering gear
Auburn planetaries
Eaton drive motors
25 gal resevoir
Top speed 22 MPH
Pump Max PSI 5000
Tread Speed 22
