Ditto...
I'm no expert, so this with a grain of salt...
My trash is
30+ years old and 90% of the wiring straight out of Toledo. When "assembling" it all together 5 years ago, I pulled a used Delco alt. out of a pile and slapped it in. While it's getting a little tired bearing wise, it's still pumping at least 55Amps. I had a RedTop for several years and due to a faulty brakelight switch, thought I'd killed it... wouldn't hold a charge (recently started throwing it on a 2A charge for a few hours at a time & it looks like it *may* live to fight another day... will have to see
). I replaced it with a high CCA Exide spiral from Sam's (first Batt. had a bad cell and died after a month or so)...
During the past 5 years, I've had
ONE *really* high amp draw situation...
Daniel in a flood (many inches of rain in a few hours) with ALL lights on, a 55W spot (no stoopid chrome KCs here!), the wipers on HI, the blower motor on HI, and straining the N.Hydraulics winch (rebadged REP8000... figure it *must* pull more amps than a "good" winch) for all it was worth for 30 minutes... 20 minute rest on the winch and another 15 minute pull (was open front & rear then
) without any issues...
Everything else has been pulling stumps out single line, a few short pulls of my trash, & *MANY* pulls on others stuck/broken junk. While it may blow all the hell-in-a-handbasket on the NEXT trip out... I'd be hard pressed to justify "high output or dual" anything! Now, certainly if you can afford it, want it for braggin' rights, or expect to pull yourself & 5 other rigs up Lower2 on a regular basis... that might be the way to go?
