ckruzer
Infidel
- Jul 2, 2015
- asheville nc
Im using a lakewood bellhousing with the 5.3 and ax15 trans. Is this bh plate "needed"? I do need to purchase the boots for it. Thanks.
I'm ASSuming the starter will bolt to the aftermarket bellhousing based on the pics in the first post. I'm not 100% based on the LS-AX15 swap however.
It is needed for starter alignment on fords, because the starter bolts through the plate and BH. I assure you it is not needed for starter alignment on a 5.3.
That's why my ranger has a tired, slow chevy drivetrain, instead of a built ford v8... lol but my starter is bolted right up to the block!It is needed for starter alignment on fords, because the starter bolts through the plate and BH. I assure you it is not needed for starter alignment on a 5.3.
You could always make a thread to see if anyone else has firsthand experience with this EXACT combo of parts and disregard anyone elses opinion or advice if their experience is with something slightly different, but still relevant.
