- Mar 20, 2005
- Hendersonville, NC
When it comes to being efficiently completing a BJ project, there's one expert in the field; our own @Loganwayne. Dude knows how to get them done, quickly with good results.
That's why when it was time to replace the Ball joints in a JK in my shop, I thought I would share some time saving tips I've picked up over the years
I know some folks like to use the c clamp style ball joint press to remove and install them. On some applications, they are needed. However, on unit bearing solid axle Jeep (and Ram) vehicles, there's no need.
I won't cover getting the shafts out and knuckles off. So do your homework to get to this point.
First thing is to smack the sides of the knuckle at the upper and lower BJ. This will jar it a little to make removal a little easier. Then I grab my long barrel super duty Matco air hammer with a blunt tipped chisel. Place the chisel on one side of the upper and give it a few seconds of action upwards. You are trying to push the joint up. Go directly across the joint and repeat. This will walk the joint right out. This takes me no more than 20-30 seconds.
Next stick the air hammer and chisel down through the upper hole and push the lower joint down. Don't forget to smack the C a couple good times just like on the upper. Alternate on opposing sides of the lower and it'll come right out.
I removed both these joints in under a minute. No foolies.
Install in next post.
plus I need to do ball joint on the dodge and I'd kinda like to try this method out.
