Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
This is nothing to do with Jeeps specifically, it would be the same on any other vehicle with a Panhard (I don't own a Jeep, never have). It's all about the type of bolted joint.
The bushing is meant to be bolted between two plates so that the bushing sleeve and the bolt are both loaded in shear (instead of bending) on both ends. That's what "double shear" means. It looks like the other end of your Panhard is attached this way. The leaf spring shackles are another example.
In single shear, the bushing and bolt are loaded in shear on one end only. This totally changes the loading on the bolt and the bushing sleeve, and there can be significant bending and tensile load components as well. The bolt is not necessarily sized for that, because the bolted joint was designed loading in double shear without the additional types of single shear loads. The bushing sleeve is not sized for that either, and would have a larger diameter where it mates to the plate if it did.
The Panhard end and bushing of that type was also designed for double shear, and the only thing keeping your Panhard end from coming off of the bushing is that relatively light duty fender washer. The axle isn't going anywhere if that happens, because the leaf springs will still locate and retain the axle laterally, but it could be a pretty sudden change in steering or whatever if that happened at speed on the street.
So I'm not saying that your Jeep is going to fly apart and kill you, but I think that it needs to be redone properly. If you're going to take an existing joint design and put it on your rig, it needs to be done right for it to perform correctly.
At the bare minimum, change that silly fender washer out for a heavier retainer plate that isn't going to turn into a cone if it gets loaded. Heck, the same parts (washer-type retainer plate) on the four rear lateral link bushings on my Subarus are at least 3 times thicker than that, maybe 4 times.
Here's an example of a double shear Panhard bracket from Google:
hope that makes sense
haha
