Well what if i drill some holes and bolt them as well? Im also going to grind down the mounts a bit to make them not so blocky lookingThe mounts themselves are fine...but you're pretty much welding to sheet metal. Those kits bolt on for that reason. Bolts are stronger than welds when put in that situation.
no no not all, I want feedback on how to make things better.I would add the bolts if I were you. I'm not trying to be a dick...Just don't want to see someone get hurt.
Your mounts are 3/16" or 1/4" thick right now the sheet metal they are welded onto is 16ga double layered in that particular area about 1/8" thick. When sheet metal is welded to something that is going to be stressed it will rip the mount off the frame when the area around the weld cracks, the mount and the weld will be fine the rest will not be.
I'm planning on plating my frame rails then weld my mounts onto the plates. The plates are going to be 3/16" and stich welded to spread the load and prevent the uni body from cracking along the entire weld should it fail.
Frame plating
The reason I ask about the upper arms is because of brake dive while braking.
I have the stock uppers atm. I have no brake dive issues.Your mounts are 3/16" or 1/4" thick right now the sheet metal they are welded onto is 16ga double layered in that particular area about 1/8" thick. When sheet metal is welded to something that is going to be stressed it will rip the mount off the frame when the area around the weld cracks, the mount and the weld will be fine the rest will not be.
Frame plating
I really want to do this on the cheap if possible. I thought of making like a right angle mount and bolting from the side and bottom with 2 HD tabs welded to the mount for the arms. not sure if that would be any better? But plating the whole frame rails is pretty much out of the question unless i get some extra money here real soon.Plate the frame rails then fully weld the Ballistic frame mounts to the frame plates. Any mount you weld to the uni body will weaken it, it will crack next to the weld.
Do your self a favor and search other forums like pirate, NAXJA, jeepforum for how others have mounted there long arms, there will be a few posts with mounts how you currently have and how your thinking of mounting them and there are some pretty bad pics of what the results will be.I really want to do this on the cheap if possible. I thought of making like a right angle mount and bolting from the side and bottom with 2 HD tabs welded to the mount for the arms. not sure if that would be any better? But plating the whole frame rails is pretty much out of the question unless i get some extra money here real soon.
Whiteyj where are you getting a stick of 3x3 3/16 for $80?
I really wish I had known about plating the XJ frame rails years ago it would have saved me all the work I now need to do to repair years of wheeling it.
Are they open on Saturday and is that something they keep in stock?Just pulled the receipt, I was wrong, it was $55. I buy my metal from Gulfstream in Holly Ridge. It's right off the coast. They're good people and have worked with me on more than one occasion, and it's hard to find prices that beat theirs. Only issue is, if I need 3' of something, I'm buying at least 10', sometimes 20' depending what it is.
Im going to drill an access hole to get to the nuts, to tighten them down.very nice! Will you be cutting the floor pan up to get a nut strip on the side and bottom of those? Or will you be plug welding those?
My very first weld
