YotaOnRocks
- Jul 17, 2007
- Madison
Anybody got any idea on what to build a work bench/welding table out of. I am looking to use for welding and a work bench as well as mounting my bench grinder and vice to. I have one that I got from work but it is way to big about 4.5 feet by 6 feet. That wont fit in the garage so I keep it outside to work on stuff. I will probably put the table up against the wall I have about 82 inches of wall space where I would like to put it but only want it to stick out about 24 inches. Ill prolly do 72 in. by 24 in. does that sound like it will be big enough or will I finish it and say damn I should have mad that bigger. Not sure on height yet I'll have to see what is comftorable for my height. But my qestion is what thickness and size metal would you use to construct it. I was thinking 2x3 .250 wall for legs and main frame under table and maybe some 2x2 .120 or .250 for supports between the legs. And maybe 1/4 inch for top. Do you all think this is to heavy duty or not heavy duty enough. The table I have has 3x5 .375 legs and leg supports and 8gauge for the top so It is really to heavy to cut up and use for what I want. Any tips from people out there that have built there own? Thanks for help and input guys
