Building code & Engineered footings???
So the rebar is drilled through the pole? If so, it’s to anchor the 6x6 into the concrete, much like Nelson studs on a steel post.
What size rebar? I’d think #5 or 6.
I’d make sure to pump out and keep that hole dry. Otherwise the water will soften the subgrade and could allow for some settling over time.
#4 rebar drilled through the post.
Holes are dry as of now, trying to get the inspector back to have them so we can get the 6” base poured.
