Some minor details here that have been left out...
The only stock cage left is the hoop behind the seats and 2 side pieces that attach to the rear fender well.
Everything else is 1 5/8" x .120" wall DOM.
Tube has been added above the rear fenders, connecting the rear most stock down tube and the main factor hoop. tube has been added alonge the floor, connecting the left and right sides of the factory main hoop. More tube has been added just inside the doors connecting the factory main hoop to the front dash supports. These dash supports are very similar to most of the other manufacturer's supports (PSC, etc.). The tube above the door opening has been replaced with 1 5/8" .120" wall DOM and attaches in very similar fashion as the factory piece. Of course, tube has been added to the front dash area, including a dash bar, a bar above the windshield, and 2 spreaders going back to the main hoop behind the seats.
All seats are attached to the cage as well as the 5 point harness for each seat. The driver's seat utilizes the factory slider on a modified PRP seat frame. This was done because John and his wife must be able to drive. Factory seat belts (with exception of the kiddie seat) have been re-installed for daily driving use.
The rocker guards I built were pre-drilled for the drain hole where the front portion of the cage can be tied into the frame when time and $$$ permits.
Removing this cage turned out to be a PITA, so we left it in place in anticipatioin that the body shop will be able to remove it for a nice paint job. Once removed, I would like to connect everything to the frame (if John wants).
I made the rear seat removeable just in case John's son doesn't go on a ride. This allows for removal for complete use of the rear area. The rear seat is mounted using YJ main eye poly bushings for easy removal when necessary. Studs and pins are easily used instead of bolts for faster removal times without worry of the attachment point coming loose.
95% of the cage was TIG welded. The dash support is laser cut from 1/4" thick steel and formed using a 175 ton Wysong brake.
Comments? Suggestions? Flames?
