Buddy Holly
Professional Amateur
- Apr 6, 2014
- North Raleigh
Hey guys. My yj developed a peculiar noise this morning on the way to class.
Specs: 95 yj, 2.5/ax5/np231 30 front open, 8.8 rear open, no SYE, odometer shows 158k
At speeds above 25 and below 65 I get a chattering noise when coasting in gear or in neutral. Sounds like it is coming from the transmission but the noise goes away when in 4hi. Both rear u-joints are brand new and the pinion angle is spot on. Front and rear diffs are well within spec and all fluids have recently been changed. The chatter changes with speed but not with rpm. The AX5 is a reman unit that has about 30k miles on it. It shifts great although it does whine some when under engine braking. Any ideas? I'm thinking it's chain slap- is there any way to tell without tearing into the transfer case? Thanks
