Calvins Cherokee
Member
- Mar 21, 2012
- Rutherfordton N.C.
Had a real rough idle and misfire. Started only when in reverse, then started all the time. Changed Tps, Iac, Coil, plugs, wires, Map sensor , Distributor, Cap And rotor button. Still had a Map sensor voltage code. Started chasing the wires to the Map sensor and found a brake in the signal wire. Just thought i woud post this so if someone else had this problem it might not take them all day to find it like it did me..LOL.. Btw this was on a OBD1 system..
