ty20404
Member
- Feb 14, 2011
- Wilmington
Alright, so I'm sure that anyone that's clicked on this is like... "what a dipsquat, it's your fan hub!" or "did you check your e-fan fuse?" Well unfortunately, I'm going to go through the details, start to finish and hopefully someone can pinpoint where I may be having a problem.
I'm going to recollect all of the events as best I can and place them in somewhat of a timeline:
Another issue that seems somewhat related to the one just mentioned, is that sometimes (rarely) when I go to accelerate, the engine hesitates even when I'm pressing the gas, then all of a sudden it surges.... But like I said, it rarely does this.
I've honestly looked at practically everything with the exception of fuel pressure, or searched elsewhere for vacuum leaks... I've run MMO and Seafoam thru the crank case, Seafoam thru the intake and fuel. From my OBDII scanner I get a MAP of about 10-12 "Hg while idling which seems normal.
I've got gobs of power with this thing, it's super easy to chirp tires, first to second... I can dump the clutch at 2000 rpm in first and chirp tires easily. It's got balls and will get up and go so there isn't any loss of power really except for those rare times that it hesitates.
Someone, for the love of god, and my wallet, please find something in here. My daily driver was recently totaled and now I have to drive around staring at my temp gauge or OBD scanner
Please let me know if you need ANY clarifications.
- Purchased 1996 Jeep Cherokee Classic, 4.0L, AX-15, 4WD, January of 2011 with a "blown motor" at 241k miles
- Thought, this is easy! Replace head and head gasket, done! No........ Bought refurb'd head, installed, bad compression, time for new motor.
- Craigslist.................................... Found 4.7L stroker built by Precision Engines from local guy w/ approx 40k miles. Heard it run in his 200X Wrangler, something sounded a little off while running, but not bad at all.
- Bought motor. While guy was tearing it down (removing all of the components to sell as long block) he called me and said "My cam gear for distributor is worn, I'll drop the price for a new cam and lifters." Done, and purchase (for 550 bucks).
- Received engine and bought a new camshaft and lifters (COMP Cams CL68-232-4), installed camshaft and lifters, replaced head gasket with FELPRO, and replaced ALL other gaskets, new head bolts, used timing chain and gear from the stroker, used everything else from my 242k mile engine (oil pan, timing chain cover, valve cover, water pump, intake manifold, exhaust manifold, A/C, PS, pulleys, etc.). I also traded injectors so that I received the proper (24lb injectors, I believe) for the stroker). Used all specs from my Haynes Manual, break-in lube, etc...
- Installed engine, fired up on the first crank.
- Overheating issues begin....
- Driving around would be fine, but would overheat slowly if sitting still (which continues to be my problem)...
- Replaced water-pump and thermostat, still continued to have issues.
- Replaced the radiator with a used one... That one leak so I continued to have issues.
- Wired in a relay and switch override for the e-fan (as of now, I don't even turn it off)
- Replaced the fan hub with one from Advance Auto Parts... That didn't work.
- Replaced the radiator with a 3 core from DPG... That didn't work.
- Replaced the water pump with a Flow Kooler high flow pump... That didn't work.
- Thought maybe I have an idling issue as far as air goes, and my dumb-ass didn't check the pre-load on the lifters when installing the cam originally (which who know, this could be my issue). I had noticed that my idle itself isn't rough but the engine does vibrate a little more than it should. So I took measurements and found that I needed some slight shimming (between .030 and .090 inches depending on valve). That didn't fix my idling issue... And it didn't fix the overheating.
- Thought that maybe my manifolds aren't tightened down enough and I've got exhaust gas escaping into the bay or intake runners... Tightened those down and that actually made a slight difference in running temps (when on highway), instead of running at 207ish, I would run right at 199* most all of the time while consistently moving.
- So because that made a difference, I decided to loosen the manifolds then follow torque sequence and tighten them down... Well it didn't improve. Once I sit in my driveway for 3 minutes, the temp starts to creep up... 203, 205, 207, 210... and so on.
- I will note that when it's cold outside, I don't have an issue... It's been at least 90 degrees out while this has been occurring lately so I've had the A/C on. If I turn the A/C off, I have yet to notice the engine temp creep up. The hottest I've let it get lately, in these temps, is 227*.
- Thought maybe I have an ignition issue, replaced plugs, wires, dist. cap and rotor... Didn't affect the idle or the overheating.
Well, now that problem is solved, but I think I am going to go ahead and put in a 200 or even 210 degree thermostat sometime soon... I'm not sure the 190 degree is really necessary.
