customjeepyj
Member
- Feb 12, 2011
- Trinity
I have a 95 yj with chevy 350. Had a carb on it and it ran fine and cool, had throttle body injection on it and it ran fine and cool, put turned port on it and now it runs hot. It will start fine run fine and the temp will slowly climb untill it boils. year old water pump brand new thermostat same all aluminum summit radiator, same electric fan by the way is feeling a little weeker. never overheated with any other setup untill I put tpi on it. The only thing that is different is the top radiator hose is a little longer and goes above the block and radiator, but with the cap off and the motor running you can see water flow. Is there something I am missing on the tpi? please help
