chevy 350 overheat! simple help! TPI guys!
iirc from my days at gm dealers, there were some small blocks that had either no holes at the rear coolant ports or restricted holes? could be a restriction caused by this,maybe? just a thought.
I had the same problem on my 90YJ with a 91 vette L98 TPI vette motor. no crossover tubes.
no fan would cool it except a taurus fan, tried every one on the market including a fancy shiny new aluminum radiator.
the TPI motors like to run around 210 anyway, IIRC they have a 195 t-stat so once it gets over that its hard to bring back with a convential low flow fan.
Sweet! So i'm not crazy! I am going to have to get a bigger alternator if anyones knows a easy swap for a v-belt sbc. My fuel pump starts screaming for power when that taurus fan comes on lol. I know the biggest I can think of is 2001-2005 dodge durango 5.9 160 amp but not sure if you can just put a single groover belt on it. I know I can just go buy $300 dollar single wire high output alternator and I might just have to go do that if I can't find an easy swap.
This is what I was going to suggest, maybe the coolant holes for the intake were blocked.
Good thinking but the block has like 5 hours on it from the engine shop. They dipped it in there cleaning thingy but that doesnt mean there is thrash in there from the radiator.
Here is article from Popular Hotrodding magazine on the TPI Intake swaps with cooling problems. The link to the article is at the bottom. The jist of it is trapped air and no coolant crossovers.
You shouldnt have to use a helicopter to cool your radiator. The issue is still there, hope this helps.
As mentioned in the story, the factory LT1 intake does not have provisions for a thermostat, housing, or coolant crossover between the heads. Because of this, provisions must be made to ensure proper cooling is maintained. One way is to use the remote mount thermostat housing, which I mounted on a bracket I fabricated that bolts under the driver's side STB brace. I used the factory TPI thermostat neck and upper radiator hose, which was flipped over and shortened, to provide return flow back to the radiator. The remote housing needed to be drilled and tapped for four (4) holes: three (3) for the coolant lines and one (1) for the coolant temp sensor, which is factory mounted in the TPI base. The coolant crossover lines were tapped from the rear of the intake instead of the front like the factory to provide more room for the throttle body and associated linkages. I used 1/2 NPT to 3/4-inch nipple fittings on the intake and the housing. The 3rd fitting in the housing should be plumbed back into the factory diverter valve and replaces the stock coolant line that came out of the factory TPI base manifold. It is important when mounting the remote housing and routing the coolant lines that the radiator cap remain at the highest point in the system to avoid getting air trapped in the system during normal operation. Upon initial start up we had to "burp" the system to remove all the trapped air, so keep this in mind to avoid any problems.
Read more: http://www.popularhotrodding.com/tech/0803phr_tpi_intake_conversion_ls1/index.html#ixzz1cYLtIjJZ
Correct me if I am wrong but isn't that for LT1 intake? I have one off a L98. He is just stating that he used TPI parts on a LT1 intake... maybe? I have been known to miss understand and/or miss read things but the title of that article is "TPI Intake Conversion - Unleash the Beast Converting your TPI intake over to an LT1 is easier than you think". Athough I would like to go to a LT1 intake Im just broke like the rest of the world. I do however love how you reffered to my fan as a helicopter. Thats just great, but I did drive it down the road the other day to get it inspected and it never overheated untill I sat still at a stop light or something so that also is indication for air flow.
I believe the rear crossover issue is the same. Speedway motors makes a cross over from the therm. housing to the heads.
on a LT1 that is absolutley true, they are a reverse flow cooling motor. crossover tubes at the back of the heads is very important as well as the crossover tube fromt he thermostat to the front p/s tube on the intake manifold. do this and get your air out and you have a good cooling LT1.
on an L98 or a lO5 top end this is not necessary.
as far as the lt2 is concerned, i would rather have a l98 in a truck than an lt1 due to the increased runner length on th el98 creates gobs more of low end off idle grunt, where the lt1 comes alive around 2500 rpms.
the only downside that i experience by comparison is that the l98 runs out of steam arouns 4700 rpms.
i just put an LT4 in classic cherk last week.
