I think the biggest factor is keeping the truck or selling it. Warranty isn't going to mean much if you dump the clutch and bust it. If you plan to dump the clutch no clutch short of a dual disc will be reliable. The cheaper aftermarket "upgrades" are junk. The oem unit will likely be as expensive as the decent single disc southbend.Oh, heck no. The stock charger is only good for about 30psi under the best of circumstances. High 20s is much more typical.
At the end of the day, I'm probably only making as much power as the later model trucks. The new stuff puts over 300hp at the tires in stock trim.
Sent from my SCH-I605 using Tapatalk 2
