72Rockcruiser
LETS GO BRANDON!
- Mar 22, 2005
- Charlotte, NC
just drive to the window
jOUIR CHICK IS HOTT, DOES SHE DO STUFF?
nOT A BAD IDEA , BUT IUNCiN WENT BACK TO AWD AFTER THE FRONT GEARS, NO MORE POWER BREAKS. i SO THINK BROKEASS HAS CVDEO OF THE DEMOLITION OF THE 37'S IN 2WD. p0ST N0W!
Just lay on the horn until they answer.
I went to the arby's last week and i sat at the menu for like 5 minutes finally pulled up and they said it had been doing it all day, either they are lazy or the only way the speaker works is if there is a car that activates it?
I'd say to cheat that type, have something metal long enough to reach the ground and open you door and "wand" it across.
Yeah... like that won't get "a little something extra" applied to your order![]()
Dude, it's TACO BELL - who would be able to tell anyway???
Oh yeah, thats sucks. I cant even go to McDs for my daughters Happy Meal without cutting off. My diesel is worth it i guess.What sucks just as bad, and I know many people here know all about it..is having to cut your truck off every time you decide to go through the drivethrough.
As has been said, that square that's been sawed into the asphalt isn't a weight sensor. Even if it were, tire psi would make no difference... Might try the large magnet on the axle trick and see if it works.
this is correct. i work for the company that installs them. hang some cans from your front bumper or dangle a chain. the metal detector should pick you up. they need to adjust their sensativity on the timerDrive throughs are triggered just like traffic lights (the ones not on timers) by one of two methods.
1) An underground weight sensor, often times you will see a square of concrete around a drive thru order slot this is where the scale is underground. most reliable, and cheapest up front. if they go out outs a bitch to cut up concrete sooo.
2) Photo eye/ photo beam/microwave detector is installed. Your truck is too tall meaning is is shooting right under it. If you can see where the sensor is park woith a tire directly in front of it.
Just sit there for a long time. They'll get confused why there arent anymore cars coming, that or they'll notice your there when the rest of the line starts honking at you.
