dana 30 on XJ will it fit on TJ
1983Bronco
On your mom in Winston Salem NC
Are all the mounts(control arms, trac bar, shocks,etc) the same on a 92 XJ as they are for a 2000 TJ, in other words, can I swap the housings? Thanks in advance for the help:beer:
Yeh it will work, bolt right in. Just remember that an xj Dana 30 is high pinion, with reverse cut gears, so you will not be able to use the gears from the tj axle.
high pinion? I thought only some of the XJ's had high pinion, what about the Grand Cherokee's
i will have to look for you, but cherokee dana 30]s are all high pinion don't know bout grands
XJ Front Axles
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints)
Dana 30 low pinion - standard cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear, 5-297x u-joints - used 00-01
95-99 are desired, no vacuum disconnect, better u-joints, high-pinion
XJ Front Axles
Thanks. I had been wondering about the year ranges myself.
Just a note, there are some late '99 produced XJ's with the LP30 in them. Probably just some overlap in parts supply, but nonetheless, they are out there.
what about zj's, I have a carrier ring and pinion form my little sisters zj, that I was gonna use in my 91 xj, are the zj's standard cut or reverse? The axle is at home in hky so I cant go look at it right now
