@CasterTroy is right in my case. I had a 2018 base-ish XLT Screw 4x4. It had the 3.31? rear gear. Wasn’t even set up for towing really other than the hitch and 5pin. I added the 6 (or 7?)pin and trailer brake controller. It did not have upgraded suspension, anti sway bars, or external or aux trans cooler. My only complaint was having to watch the trans temp. This truck really surprised me and led to me going with another one but this time I found a max tow package. The 10 speed in this one isn’t as smooth as my first one but it does really well (plenty online about the 10-speed issues). Temps aren’t a problem at all. Max tow seems more stable. 35 gallon tank is great. Locking rear differential is cool sometimes.And that is why I asked this group. I don't know squat about newer trucks.
@shawn says a turbo F150. So what is the preferred engine to do what I would like to do? Is this the 3.5L Ecoboost?
My mileage on the dash is actually pretty close to the calculated and I can easily get 20-22 up to 75 on hwy trips. Faster than that and mileage will start to suffer. I drive 80-85 a lot and it’ll drop to 20. Running 60….on flat ground, about 23. That’s all in eco mode. But I typically drive in sport mode. Overall mileage is usually about 18-19. It’s easy to get 15-16 too if you’re feeling froggy. The trucks are actually fun to drive and feel a lot lighter than they are. The torque is always there in tow and sport mode. Regular mode isn’t terrible but if the truck was manual, sport mode would be more like how I’d drive it as far as shift points and holding gears go.
The 10 speed is a cheat code. I’d consider a v8 next time just to see. If you want to make any exhaust mods you better go with the v8. The EB 3.5 sounds like shit.
Make sure you get a late enough model to get the 10 speed.
I’d recommend one to anybody for pulling a rig on a tag trailer or up to a 30 hp tractor on equipment trailer. I’d also like to drive a Chevy with the new trans. Haven’t towed with one of those yet.
