RHSCTJ
- Jul 1, 2008
- ROCK HILL, SC
Don't forget a e250 semi float 60 with factory 35 splines and disc brakes. Cheap, plentiful, strong. I think that would be ideal for a 8 lug 44 frt
I told Nate to charge you doubleThats what I'm thinking right now. I've got my eye on an 8 lug full width D44 with cromos/detroit/hi-steer/hydro assist, and already setup for an XJ/TJ. Buy that, regear, drop it in, then run my 2.5" spacer/adapters on the 8.8 that I already have. If I feel so inclined in a couple months (or years), swap in a full width 8.8 or 9", and get some 8x6.5 pattern shafts or just buy thinner adapters. Part of the reason I de-tonnified my jeep was the weight. She was a porky beast.
So thats why the price went up...I told Nate to charge you double
Even if I find a SD60 for $400, I'll spend another $400 narrowing it and getting a shaft, then $300 for the TJ brackets and the time/effort of welding it on, then I still need gears/locker/histeer/ram. And thats assuming the hubs and brakes are good.SD60, narrowed long side to 78-79 HPD60 length. The offset centersection will help with uptravel and packaging. Redrill the UB to 6 lug, you machinist you. High steer from Ujoint Offroad here in Fletcher. Buy my lunch when you come and pick up.
Toy FJ80 FF rear. Light, strong as all get out.
As a member myself of the built to the hilt D44 club, you know yourself you'll spend serious coin to make any 44 take what a nearly stock 60 will...
Or pull a @shawn and swap some JK Rubi 44s in and be done.
A built D44 will hold up just fine sitting in my garage anyway
If money were no object I'd order some of the new Spicer extreme axles. Wanna sponsor me?
Yes same jointSo could I run the Yukon Super Joints from my D30 in the D44 shafts?
Instead of a ford axle you would need to find a j10 or j20 44. I think i recall 80-86 being the driver side differential.OK, since Matt made his mind up I have a follow up question.
How does any of this advice change if a low pinion front axle is absolutely required?
High pinion is stronger driving forward, low pinion is stronger when backing up. Otherwise no real difference other than the pinion location. Somewhere there's a thread or two where I go into detail about it, but I can't seem to find it. I personally prefer low pinion front because of the weight distribution. If going uphill forwards, you'll be light on the frontend. If going uphill backwards, you'll be heavy on the frontend, which is when you want strength in the R&P.OK, since Matt made his mind up I have a follow up question.
Do nothing for now, and eventually upgrade to a D44 front to match the 8.8 rear. I ran 36" Iroks (37" actual diameter) for a while on a D30 with no issues.
I'd love to have a Bronco, but they are kind of like an Iphone: simple, decent hardware, WAAAAY overpriced@jeepinmatt - my vote would be to sell it and buy one already done. It's only a wrangler after all.
While strength is a consideration, the packaging takes precedence here for me... I have to fit the starter, exhaust, and driveshaft all down the same side of the transmission. In fact, not only LP, but the shorter the short side the better.High pinion is stronger driving forward, low pinion is stronger when backing up. Otherwise no real difference other than the pinion location. Somewhere there's a thread or two where I go into detail about it, but I can't seem to find it. I personally prefer low pinion front because of the weight distribution. If going uphill forwards, you'll be light on the frontend. If going uphill backwards, you'll be heavy on the frontend, which is when you want strength in the R&P.
When trying to find the thread, I stumbled across this advice I gave to someone, which seems humorous in light of the current thread:
