Ok so just tested the fuel solenoid wires with key in on position, now power. It gets power when I turn the starter over. Is that the way it's supposed to be?
Sent from my Moto Z (2) using Tapatalk
it should get power and hold power for 5 seconds after start to allow for oil pressure build and the switch and EOP to take over. disconnect the oil pressure switch and try it again ( switch is normally closed, which means circuit is powered to open EOP relay and not allow fuel ) disconnect the switch that should kill the power to relay and light and allow start. Oil pressure switches switch to ground, which completes a circuit to turn on light and other items ( EOP in the case )
if you look, every wire has a number printed on it at each connector termination, these are the identifiers on the schematic
It will start and run while in start as the fuel solenoid is powered Pull in on start, Hold in is powered thru EOP relay and that's what keeps it running. ( see schematic fuel solenoid ) Sa is pull in power, 22 is hold in power, 13 is the wire you need to find at the EOP relay. 13 jumpers to 22 at that connector you showed in a previous picture. ( see numbers on each end of wire )
each wire on the fuel solenoid has a function, its not hot and ground, solenoid grounds thru body to engine
you should have power into the EOP relay on wire 8 running or not with key on.
disconnect the oil pressure switch and the EOP should pass power with key on, if not the relay may be bad, even if it clicks it can be bad.
Kubotas have a history of failing oil pressure switches.
