Do you think I need a diesel
This is covered a gazillion times. And every case is very different. As for yours, more info is needed such as "where" you plan to tow.
Bottom line, If towing vehicles (5-6k pounds) plus gear in mountainous terrain, diesel has an advantage up hills. If local to Cary / Raleigh, I towed with a 1/2 ton for 20 years around here with absolutely no problems. F-100 with 3 speed and a built 302 never let me down and still there as a fall back. Only item I replaced in over 200k miles was the clutch twice. Trick is to never use overdrive and drive smart with adequate following distances in case someone decides to stop in the middle of the interstate in front of you. 1/2 tons are not fun up and down hills but get the job done. Only advantage I see with an older 3/4 is better brakes from factory. As for a new truck, technology changes yearly and always improving over old technology.
Gassers are cheaper in maintenance with 5 quarts and a $4-5 filter every 5,000 miles. Compared to 15-18 quarts and a $10 filter every 5,000 plus recommended $10 fuel filter every 10,000. Although diesels get a tad bit better mileage, $2 a gallon for gas compared with $3.50 for diesel(currently). Then comes $600+ injectors compared with $75 for gas injectors and $20 set of plugs.
Diesels are (most likely) more dependable except on very cold starts without a block heater plugged in. Diesels tend to last 300k-500k if maintained regularly compared to 150k-300k for gassers. But again, tolerances are better all the time and mileage is better and better with new technology gas motors.
I do recommend a trailer with towing capacities (rated axles) for over the weight of what you are towing. And weighted tags over the total amount you ever would want to tow. Since your load is a known factor, simply load up, fill up with fuel and go weigh on a certified truck stop scale and add for extra passengers and even more gear before purchasing the correct weighted tags to be sure you have enough.
Gassers are simple but certain diesels are simple as well such as an early cummins.
Probably missing something but a search for maybe "diesel towing" would yield enough reading material for a lifetime. And every lemon sits for sale next to an identical lime. "Luck" serves well when picking a vehicle.
Do your homework before purchasing a tow pig and trailer combo. And be sure to have your tow pig with you when you try out trailers for I just MAJORLY overhauled my 20' gooseneck for it was built for my old F-100 and was too low to fit onto my new (to me) Dodge Cummins.
Been thinking about getting an aluminum single hauler and trying that too.
I'll be on the lookout for a used Featherlite for the both of us then :lol:
Except for maintenance/parts on a diesel truck cost 4x as much..
Only the motor parts cost more, and Cummins owners who leave them stock don't have to worry about that.
Also resale value on a diesel is great. I've owned several and had then for a couple years and re sale then for more than I gave for them
Can someone please elaborate and quantify what the upkeep/maintenance costs are that are so much higher on a diesel (ignoring newer systems with DEF/regen/overcomplication)? I read this in every thread about this topic and would love to know what to expect once my truck gets high miles on it. My truck only has 330k on it now, but so far it's only been oil and filter changes, so I feel like I'm missing something.
I believe the cost reasoning has been well stated, as for your miles and service thats great. Its by no means the standard any longer. My father was a service manager for 30 yrs, even he questioned the real need for a diesel when they where built to run forever. Even then hardparts and the guts of the unit cost often 200 percent more to repair. Does that make him right or an expert by no means. But he did runa shop with lots of both through the doors. I like my current truck, a diesel. But unlike the original poster it gets towed with weekly, almost daily. Its emissions free, which is a huge plus. I currently would not buy anything with this stuff, the reliability and mpg just isn't available and accross the market segment proven. Its all opinion in the end and what a man justifies his dollars on. Either way any individual will find a justification for his point of view.
Diesel. Cause gas motors dont go clackety clack.
