LR Max
- Mar 2, 2007
- Atlanta, GA
Month 2 of use. Been good.
Battery power varies. I went out wheelin last weekend and left said phone in my car all day, no use. Battery was in eggscellent shape.
However a couple days ago I showed a bunch of photos on my phone, then a bunch of texts and then on the internet a lot. Battery sucked
I've never had to charge half way through a day (if I started with a full charge at the beginning of the day). However I do take care of my battery, full discharge. I always do full discharge because I spend 98% of my time near a charging source (work computer or at home or in my car).
The stock photo gallery viewer sucks. I'm gonna look into downloading a new one.
Advance Task Killer is CRUCIAL. If I open a bunch of apps, I'll just use task killer to kill them all. Saves battery power. Great if you use your phone a lot, but then it sits. Do the task killer before setting it down.
Also Power Manager is awesome. Instantly tells you how much battery power you've got, can turn on wifi instantly and same with GPS. Easier to use than going into settings.
As of now, my phone needs a charge once every 2 days or so. I just charge it on my work computer.
Speaking of which, the wall charger is WAY faster. However I always forget to do it at home.
The nice thing is if I ever wake up in the middle of the night and can't sleep, I can just reach over, get on my droid and look at pirate
. Easier than getting a computer started up.
My $4 car charger has turned out to be...well...a $4 car charger. Only works with a certain orientation in the cigarette lighter. However I rarely use it so it is fine. Charging also seems to be quick with this charger as well. If you plan on charging in the car often, then spring for a better charger.
My cheapo screen protector and case still work fine. The case is already faded so its half blue and half clear. Whatever, still works. It isn't "crappy" enough for me to replace. Screen protector has a few scratches on it. Does its job.
Be careful when picking cases. A lot of them are bulky. Just take up extra room in your pocket. Pockets are staying the same, but phones are getting bigger!
Compass, DOWNLOAD IT. Very convenient to have.
The google maps brings teh awesome. Add the traffic layer and you are golden. The google nav works great. Used it last night to find a bar because the jerk who "knew" where it was spent all his time talking trash and got us lost
. Droid saved the day.
Droid light = win. That is all there is to it.
I had the "pattern lock" on there. Waste of time. I just don't put my SS and bank acct on the thing. Not like I need to check my bank acct every 3 seconds.
.I've never had to charge half way through a day (if I started with a full charge at the beginning of the day). However I do take care of my battery, full discharge. I always do full discharge because I spend 98% of my time near a charging source (work computer or at home or in my car).
. Easier than getting a computer started up. My $4 car charger has turned out to be...well...a $4 car charger. Only works with a certain orientation in the cigarette lighter. However I rarely use it so it is fine. Charging also seems to be quick with this charger as well. If you plan on charging in the car often, then spring for a better charger.
. Droid saved the day.Droid light = win. That is all there is to it.
