mw312003
Member
- Jan 1, 2011
- taylorsville
Need some input guys on what chip do you think is better for a 2001 5.9 cummins either a edge comp box or a super chip flashpaq . Thanks
While this can be true, there is little evidence that a box will decrease the life of the vp. If the truck has ever ran Sub 10psi your vp is most likely going to fail. If a box such as.a comp causes failure its generally as soon as you install it, it damages the driver solenoid (yellow wire)Edge comp box all the way! but you must take the following into consideration
If you add a programer to the 24v...
You will destroy your stock auto trans or stock clutch.....
You will make the IP go out faster...unless you put a FASS or Airdog lift pump on it.
Basicly if you aren't able to replace all this expensive shit.....leave the truck stock.
The comp box made my truck roll coal and it was fun. I took it off because I didn't wanna put $4,000 transmission/$2,000 IP,LP in it.
Think really hard before you juice it up and run the shit out of it![]()
