Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
Needing to adapt from a 4 plug dryer plug to a three plug for my welder. Do they make adapters or am I going to have to make one
That didn't hit me until after I posted it but if I did that I would need to be able to switch it back since the welder isn't mineBuy a dryer plug, cut off old welder plug, attach dryer plug to your welder lead, leave ground lug unused?
If it was his I'd cut if off and return it bare wireOffer to put a new plug on your friend's welder when you're done? Unless it's @McCracken's welder. In that case, leave the dryer plug on it.
That's what I was thinking I was going to have to do but was hoping someone had already marketed a ready to go adapterYeah, either take off the welder plug and splice it to a 4-pin dryer pigtail (they don't sell dryer plugs separately), or buy a dryer pigtail, a 4" square junction box, strain relief clamp, and a 3-prong 50A socket to match your welder plug. Basically make up a little transition cable that goes from the 4-pin dryer plug to a welder receptacle. If you think you might use it more often than that, go ahead and make the "pigtail" piece 25 or 50ft or whatever long.
The tard is strong with this oneNeeding to adapt from a 4 plug dryer plug to a three plug for my welder. Do they make adapters or am I going to have to make oneView attachment 196838View attachment 196839
Will that not just plug in only missing the ground? I have a bunch of different adapters for my floor sander. It seems no 2 houses are the same when I needed to work so I built a short pig tail with the correct female end and the other has just the blades connected to the wires. I only have to change the ground blade out occasionally and use the needed plastic clamshell and electrical tape it shut. I also have a 300' cord with a 50A breaker on one end and 4 bus breaker panel and attached outlets in the other. I'll snap a pic or two tomorrow to help make sense.
If I change the dryer plug then Id have to change the dryer wire as wellReplace the wall plug with a 3 prong. Any home improvement will have what you need for a few dollars and it's very simple, maybe 3-4 minute fix at most. I would imagine an adapter would cost over twice as much as just a plug anyways. You don't really want to change the welder plug for all 220V welders are 3 prong and your's would then become an odd ball???
Make sure you have the correct wire gage with distance to the box and the correct sized breaker.
Most welders are 50 amp.
No, they're not.
"Most" are 20-30A at 240V, and even then, it depends on your output power. If you're not running the welder full-bore, it's not pulling full rated power from the wall.
And if, by chance, you happened to plug your big ass 50A welder into a 30A dryer receptacle, it would pop the breaker. That's all.
Like the whole purpose of correct wiring.The 30 amp breaker will protect the #10 wiring....
But if your wiring is inadequate and you KEEP popping that breaker what is bound to happen???
