Estonian
Member
- Oct 25, 2008
- Raleigh/Garner
ok, so my 97 TJ 2.5 4 cyl engine AND tranny are trying to retire after many many hard miles on it. I just purchased a rolled over 03 wrangler with the 4.0 5-speed with only 27xxx miles on it for a low price and want to swap the 4.0 into my 97 TJ. I have the WHOLE donor jeep and it still runs fine just the cosmetics of the jeep are real bad now the question is that does the 03 wiring harness differ from the 97 ? meaning that is it a plug and play under the dashboard? i know i have to swap over everything engine,tranny,tcase,ecu,harness and all which is not a problem but i just wanted to make sure it was not too much work to make the guages work under the dash without toooooo much headaches. i know some of you will tell me to just sell the 97 tj and buy a new one with the 4.0 already in it but the reason i want to do the swap is because my 97 is in perfect condition inside and out with ALOT of work already done to it (axles,gear,lift, etc,...) and if anyone knows of any curveballs i will be running into with the difference in the two jeeps. (97 2.5 current - 03 donor 4.0 ) would be greatly appreciated. thanks
