F450 Dana 80 / M300 / S110 ? REAR AXLE, 2005+, ford 10 lugs
Yay!Gurrr
Better Faster Stronger
Moderator
N. N. Raleigh, NC
picture here
F450 Dana 80 / M300 / S110 Rear axle, 2005+, ford 10 lugs
Can be flood damage, broken gears, pinion, brakes, ujoiut flange, etc.
WMS-WMS ~75"
Pics showing me where / how the caliper mount [they are different]
May consider a brand name, full on, air setup...
I added to m300 2017+
i also added the S110 ugg
-Drop out 3rd
-Older design
-bead bearing or to much backlash ?
Might better move this.....
Call F-Trucks in Denton, NC and see if he has one.
F-Trucks​
Address
188 Garner Rd, Denton, NC 27239, United States
Phone
  • +1 336 859 8211
@Yay!Gurrr Called a bud in TN that knows his Ford shat... asking if he was sitting on one. He response [paraphrased]:
- Aside from OBS F-450s, which had D80s, but with a smaller 10-lug pattern than your "new" front axle...
- There are NO factory '05+ "F-450 D80s", as the 450/550 trucks all went to Dana S110/1S35
He said:
- what you're looking for is the '05+ E-450/550 which DID come factory with a D80 & big 10-lug pattern like your new front beam axle (guesstimated might be $5K due to rarity, unless you find a yard full of vans)
- or an S110/S135 to get the big 10-lug pattern and be prepared to rebuild the spring perches to fit the "van width" (which is all over the place vs std truck/CC frame widths) *much more reasonably priced than the above*
1999 and up 450 and 550 have different housings the 450 the housing has round tubes and the 550 housing has square tubes at least the trucks i have has the best i can remember.
S110 was found in Kodiak/Topkick and plenty of the bigger U-Haul trucks, medium duty trucks and buses. Hope that helps your search.
Kodiak Dynasty is a FB group with lots of parts for the Kodiak trucks.
Well I was able to get one, and in fact it is 75.5” which will help me greatly.
I get f550 one
S110 = ~.35 wall and housing but the other one
S130 = ~.39 wall, this amount to ~20# total difference
And of course it's stronger
gears 4.88
flat round input on pinion
what's next .... nothing
I get f550 one
gears 4.88
I've been into a couple of those. The carrier bearings can come apart under heavy abuse. I'd take a good look at the drain/fill plugs for any evidence of accelerated wear (beyond normal on the magnet).
Definite, I plan to pull it apart.
At a minimum, new seals what not.
with 250k miles i wouldn't be surprised if the
pinion bearing need a refresh
+20 year of gunk in there, needs a cleaning.
Work progress
Cleaned it up.
Got pinion and diff bearings
pinion seal
Sliced off spring mount on one side
Checked it is 4.88
Need to reverse one shock mount
Working on today
Cart, 2" non-steel --> 3.5" steel wheels
:flipoff2:
