Here is some pointers
-soil is more than dirt. it is alive. it is porous, filled with organic matter, water, air, microorganisms, worms, critters. Its a jungle and it takes living soil to produce a healthy (high brix) harvest.
-brix (plant sugar level) is your most important thing in the plant. did you know a pest does not have a pancreas? it can not process sugar. pests will pass up healthy plants and consume the sick (low sugar) plants. this was God's way of giving us a sign of knowing what of the harvest NOT to eat...
-the most important tool you can own if you want to farm, is a brix meter. You can call it your bullshit meter. Anything someone wants you to use, if it doesn't increase the brix, throw it out (broad statement for a dramatic point)
-carbon in your soil is extremely important and one of the most important amendments you can do. carbon holds up to 4? times its weight in water. there is a similarity between people today and common plant ailments. look up the symptoms of prolonged dehydration (the dehydration, has nothing to do with lack of rain).
-understand what chemicals and gmo’s are doing. understand glyphosate and what it is doing. a study by USDA proved: organic corn has 14 ppm of manganese while chemical grown corn has only 2. organic corn has 6,130 ppm of calcium and only 14 in chemically grown… the list goes on
-another usda study conducted showed: since 1975 agriculture has seen the greatest loss of vitamins and minerals in their harvest in recorded history of mankind. In this study it showed: Apples, Vitamin A: Down 41%. Sweet Peppers, Vitamin C: Down 31%. Broccoli, Vitamin A and Calcium, Down 50%. The goes on.
-characteristics of sustainable soil. drains well and warms up quickly in spring with no tilling. does not crust after “low-till” or planting. soaks up heavy rains with little to no runoff. stores moisture for droughts. has an abundance of bacteria and other microbials. supports high populations of organisms. resists erosion and nutrient runoff. does not require increasing fertilizer inputs every year for marginal results. produces healthy plants with high brixx.
-good soils is usually: 45% minerals, 25% air, 25% water and 2 to 5% organic matter. one acre of Healthy soil contains approx 7,500 Lbs of living organisms and plant material (organic matter)
-water facts: one inch of rain = 27,154 gallons of water per acre. average healthy soil with only ***1 %*** total organic matter can hold approx. 16,500 gallons of water per acre (0.6 inch rainfall). average healthy soil with only 2.5% total organic matter can hold approx. 41,250 gallons of water per acre… digress back to the dehydration issue. Water is at the basis of all life. Plants, animals, people. All majority water. The point here; if your soil is crap constant rains is what you require, and God forbid a dry season comes on...
-we have met farmers who think wayyy outside the box. not commonly known. every plant takes nutrients, but it ALSO inputs nutrients into the soil. God created weeds too. They are putting nutrients into the soil where something is deficient. A completely healthy soil has virtually zero weeds. we’ve seen it, we’ve done it. One farmer we met would make compost teas from the weeds he would pull and spray this back on the ground. the weeds would literally “turn off”, tricked into thinking they are not needed. wild stuff.
-when you do have a weed issue, the best thing to do is plant a cover crop. also don't buy into the habit of using plastic to cover your soil. you might as well microwave the soil. go to a farm that does this, and poke a hole in the middle of the day and feel the heat coming off.. you're cooking your soil. mulches can and obviously do work. but a cover crop will be more beneficial. you can google a guy on youtube “back to eden” and he shows how to proper use mulches. the right mulches promote so much organic matter that very little fertilizer is needed for simple gardens doing crop rotations.
-i have attached a picture showing fodder. this was taken in early spring just before planting. this should have been consumed by the soil biology. a second picture shows where one of these stalks still standing was pulled up. you can see that even the root mass hasn't biodegraded! this is very very poor soil. A microbiologist we had as a consultant before he passed once said: “the soils in the US are so poor, if people only knew how close we were to to not being able to grow a single thing”. we reversed one of the largest citrus farms in florida. you could stand at the edge of the field and hear: plop, plop plop, plop, plop plop plop. The citrus falling off the trees. the trees are so undernourished, so sick, it cant even hold up the fruit. the farmer told: his grandad farmed a dozen boxes per tree, his dad less than half that, and now he gets one per tree… you could go long on US citrus right now and be setup to make a lot of money. very very near collapse.
call me anytime shawn. its what we do for a living, and you know you're doing something right when you double the yield of a 6000 acre farm, or when welches pays out triple for the new high brix grapes coming in…
