kaiser715
Doing hard time
- Jun 1, 2006
- 7, Pocket, NC
So...I got a house that needs work. Kicking around whether to fix it up and sell, or dump it to a flipper. Needs a good bit of work, but the house has good bones, and some good things like good landscaping, newish roof, new hvac, etc. 3600sf, built in 1956. Hardwood flooring in all of upstairs (main level), a couple of rooms under carpet. In todays market, might get $325-350 for the house fixed up...$150-175 to a flipper.
First up...plumbing. first issue really not a problem, ...copper supply lines are shot, need to re-run pex everywhere. Good access via basement. Just time and money.
Problem #2) It looks like the main sewer line (cast iron) under the basement slab is rotted/collapsed. Barely draining, so had a plumber come over, he tried rooting it, and brought clay back up. There are a couple of 45's...I guess the machine went straight thru one. I got one toilet pulled up now, and there is not even a hint of sewer gas coming up...so I'd say 100% clogged. I have four options here:
A) cut the slab, dig a trench (55' total), put in PVC under the slab; or
B) dig down outside (on the back side of the house) down to the footing level (7 feet down), and run PVC out from under slab (minimal slab cut for toilet, etc), then around house to the front (plenty of slope, but lots of digging, have to tear out and rebuild brick patio); or
C) run a PVC sewer line out the back of the house, but buried just a couple of feet deep, and only serve the upstairs bathrooms and kitchen, and move the basement bathroom (long story, those walls need rebuilt/moved anyway) to the front side of the house where I can tie in where the existing PVC comes up to the house, again with minimal slab cutting; or
D) same as C, but leave basement bathroom in same location, put in a Saniflo upflush toilet, or a septic sump and ejector.
A) might actually be cheapest, but messy. What, 10k? B) might cost 30-40k with the patio and all. D) is just asking for trouble.
No furniture or stuff to work around.
Any ideas/advice? Maybe I can post up some drawings later.
