frankenyoter
No Rain, No Rainbow
- Mar 17, 2009
- DARK CITY
Just cut it already
Circular saw and set depth. Wood chisel to finish out corners. Who doesn't own at least one circular saw?
OK so assuming your siding isn't over 1.5" thick, screw a 1x6 to the wall and use it to run your saw across. (;
BB gun em!? They'll eventually get the point...Now if my neighbor would not keep his flood lights on all night....
It's common for the sheathing to be fiberboard sheathing for that time period with no house wrap type air infiltration barrier.
Some of the cedar siding is getting pretty soft in some spots, so will likely need to be replaced. If we do a full re-siding of the house (likely with Hardi, which is much cheaper than cedar these days?), I imagine we'll have to bring everything up to code with sheathing, water resistant barrier, etc.? Well, at the minimum to satisfy warranty requirements for whatever gets installed. Don't know if Hardi is rated for install over anything but sheathing...
If you take the extra siding and flip it over and mount it over the hole (may have to rip to get it to lay flat, caulk/liquid nail behind it to existing siding and nail. mount fixture and worry about tearing the side of the house off later. (not sure about just the foam board behind siding, i've removed cedar siding from a house from the same time period [maybe earlier even, 80s?] in lake lure and saw tar paper but there was plywood behind it..)Didn't read all the post. But I've cut a 6" section of the siding and flipped it upside down.
