Ford 6.0 gear recommendation for 38s
Hunter44
Lexington
2006 6.0 bulletproofed, Innovative Diesel Xtreme X tune, stock trans. With 38s what do y'all recommend? I don't tow or anything but cruise the street. Couple knowledgeable guys told me 3.73's would kill my transmission with that size tire.
Stock tires are about 34". I'm sure you've also read that, in general, a hot tune will kill your transmission. Assuming you have 3.73 gears stock, the size difference from 34" to 38" is 12%, so mathematically you'd need 4.17 gears. Since that doesn't exist, and you're trying to save the transmission, you'd want 4.56's (I don't think they make ~4.3 gears for SD axles).
on the bottom end, yes.
Would limit your top end potentially.
You dont mention, but I assume it is a stock auto.
Don't know what your stock gears are either though...
It says stock auto in the original post, actually. Stock gears are 3.73. The trans tune that's with that Xtreme X tune locks the converter in every gear but first, so that's worth mentioning.
I told you 4.56 gears probably 5 time already too.
It's says stock Trans, not stock auto....
Everybody knows anyone who calls it a "trans" is referring to an auto, and a "tranny" is a manual or a transvestite.
If it were a manual, he would have probably mentioned a clutch somewhere and the worry of destroying a transmission also leans towards it being an automatic. Just saying.
Agree it leans, that's why I said I assume..but you know how that can work.
