ckruzer
Infidel
- Jul 2, 2015
- asheville nc
Project Speedbump is at it again.... this is seriously starting to take the joy out of the build
The passenger side header isn't fitting. The block is 1.5 inches closer to the P side for steering shaft clearance. And I have measured and measured. This doesn't change the motor mount location. Motor mounts are properly positioned. Trans is properly in the middle with the 1.5 offset.
Best I can figure. These eBay headers are not true and the pics seem that way too. Can anyone offer any advice? Yes I plan to contact the seller but not high hopes.
Driver side fitment
Passenger side and you can see the close up of how much it needs to rotate and it's already touching the mount.
Best I can figure is try to raise the engine with spacers on the trans mount. An inch and see if that helps clear the mount? Here is pics of the headers side by side
Driver side fitment
