mommucked
Endeavoring to persevere
- Sep 26, 2011
- Rural Apex n.c.
How could anyone (except the folks who will make money at our beautifull states expense) think this is a good idea? I'm no expert, but I have done some drilling/deep rock boring, for a soil testing company in the 80s. From what I've read Fracking involves drilling strait down 1-2000 feet to reach the gas trapped in shale deposits, (or to a depth they think is safe to Frackit and not disturb or contaminate near surface water tables > your well ) or cause other surely UN-fixable/UNderground problems . At the bottom of the bore they turn the drill and drill multiple HORIZONTAL bores through the ground, ( picture roots on a tree buried to the treetop), maybe right under your property if you owned the earth straight down from your property lines (how would you know or prove it? you sure wouldn't dig it up like an encroaching septic line), then they inject water- ( most likely from the river which is also the lowest point on the surface and closest to the fracking BS) -and chemicals to crack/Frack the gas out of the shale so they can tap it like some great underground Earth fart. Then the injected, infected, contaminated water is pulled back out to the surface ( w the gas) to be treated and dumped back into the river ( so it can float/disipate the gas bubbles and seeping bad water from the fracking that pops up from riverbed) and make it all safe to fish, swim, build a campfire or smoke down by the river. I'm sure it would be easy to remove all of the gas, and ALL injected water and chems. from the ground once they pump them down there right? and water only flows up and down underground, not horizontally right? and the earth is solid, no cracks or voids that might transport these contaminations miles from the actual fracking site right? Any experts in Geology/ or other related knowledge care to tell me how this cannot/willnot go wrong in an unfixable way?......... I am all ears
