Good deals on 2 post automotive lift?
@jeepinmatt
I am looking at this same lift for my new shop. How's it working out for you??
Set up wide, can it still reach in and hit the frame rails on an older Jeep, about 36"?
Wanna come help with the install on mine?? :)
Still works like new. I've had a variety of things on it. Heaviest was my Superdoody at about 8300lbs:
Not sure why I don't have any pics of it raised up, but it's been all the way up multiple times.
The most awkward load was a monarch lathe, at about 7600lbs and 15" wide (arms probably 10" center to center). I lifted it off of my trailer and set it on to the buyers trailer. That was sketchy.
It will also hold a jeep for months at a time:
And is great for removing lawnmower blades:
My car was the most difficult thing to pick up with it. The arms are about 1/4" too tall, and have to be fully shortened to fit past the tires but then extended again to reach the lift points, which is a pain because there's no room to work. It also causes your exhaust to fall off:
If I had it to do over again, the only thing I would debate is whether to go symmetric or asymmetric, but I'd probably still go symmetric. The extra width still doesn't seem wide enough. I'm also really particular about centering the load mass, which almost always puts the drivers door right between the posts. So you can't go too wide. I have yet to need the extra height, but like knowing it's there. The lift height is too low, but is in line with everything else in the industry if I remember right. That also depends on where/how you pick up the vehicle. On the truck I have to use long extensions up to the body mounts in the front, and no extensions on the rear, so it doesn't lift as high as my jeep. The jeep has frame space and clearance for about 10" of extensions under the pucks. So it leaves plenty of room.
I'n an effort to maximize center shop space, I mounted it about 2ft off the sidewall of the building, which was a mistake. It effectively ties up the entire wall, so there is no room for equipment or storage and is crowded to walk by. Eventually I will move it over about 4ft.
Installation was easy, but I had a forklift to stand the posts up with and lift the crossbar. Borrowed a big hammer drill from a friend. If you have a way to hoist from above, it will be no problem. You can walk the posts around by hand. One tip: clean the anchor holes very well after you drill them. I'm a detailed, critical person, and my dad is not. He did one side, and I did the other. He vacuumed the dust up with a shop vac, whereas I vacuumed and wire brushed and hit it with an air hose and vacuumed several times. I tightened my side up once, and checked it after a couple weeks, basically hasn't moved since. His side has been tightened multiple times because it never bites as well because of the concrete dust still in there. It holds the recommended torque per Bend pak when you tighten it, it just loosens a little after use. This is another reason to relocate the lift, haha.
You will have no problem with 36" framerails. I think the 2 stage arms touch in the center, but the 3 stage are maybe 12-15" away. Maybe more. I don't remember.
If you have any questions/issues during the install, shoot me a PM. If you were closer i would come help.
I am not sure where you plan to put it in the building, but moight consider installing the lift on the pad and let them put the building up around it, if it makes hoisting/lifting easier..... or if they are using a crane/lift to install the rafters, might have them help set the lift for a little pocket change.
So, this is a totally different direction but just wanted to throw it in there in case somebody else is considering...
A buddy of mine is a former master mechanic (now works for the state) but still does side work. He has a 4 post that he stores a racecar on, but his primary shop has an in-ground single post deal.
That thing is the bees knees if you have limited space and don't want to have to deal with the posts being in the way, or have height limitations in the garage. The arms can swing around almost any direction. He says he rarely has any issues w/ access to the belly, he just replaced a JK transmission no problem. When it's down, only the arms stick out, and those could be removed if needed and it's be almost unnoticeable in the floor.
Biggest issue is the installation is a lot more $$, but frankly it's more practical for a typical small garage. None of this issue about posts getting in the way of doors, or blocking whole walls of space etc. You just gotta plan carefully b/c once it's in... it's in! No moving it later :D
I looked at those when I was shopping, but they just didn't have the weight capacity I needed. Very cool indeed.
I was liking the rotary Smartlift....2 post in-ground....all that is exposed is the arms. Full access underneath unlike a single post in ground.
Groundwater is protected by a poly housing.
But....looks like about 12k. Not bad....and probably safer....(no anchors to rip out)...and no columns to work around or bump.....hmmmm....but that 9k difference kills it.
SL212 - Smartlift In Ground Lifts | Rotary Lift
The rock I have hit at my place would make this very expensive to install.
Favorite year of 250 grill ever
I thought in-ground lifts were on their way out, if not out altogether. The EPA frowns on hydraulic leaks underground.
Buddy said it's all encased in a poly coating of some sort to avoid the EPA concerns.
Now that I look at it, that's similar to my buddy's. I was thinking of it as a single unit but I guess it is 2 posts.
$12k is a tough pill to swallow, but the convenience is huge, especially if you have an existing garage w/o a lot of room. I could be wrong but I believe that can be put in a normal slab w/o needing extra thickness.
If you have $12k and a lot of room, you can buy a lot of convenience. You can buy a 2-post, and a 4-post, and an A-frame gantry, and a 2-stage compressor, and some other stuff.
Thanks, I agree. Overall something about the 08-10 Superduty's looks tougher and better to me than the newer or older generations.
Have a friend that has one idendtical to yours. King ranch?
No, just a Lariat. Though the only difference between KR and Lariat was the seat leather, badging, and I think the KR all came with Nav/Backup cam. To keep it on track, here it is on the lift simulating lift at 0", 3" and 6" (or maybe 2" and 4").
Who did you get the lift from BTW, I'll be in the market soon for a Bendpak (a new gray one, happily). I was hoping to have broken ground on our shop in time for my birthday. In 3 weeks. It's err... only a few months behind schedule, but at least I have a scapegoat that isn't me this time.
I got it from BendPak directly. Calling them worked out cheaper than anywhere else I could find (not by much, but a little), and free shipping to a freight terminal. They sometimes have scratch and dents for a little cheaper, but obviously options are limited. There was some Bendpak rep posting on garagejournal forums so I PM'd him and went from there.
If that's the guy I think it is, I may have already been in touch with him.. Actually, maybe that guy was a vendor and not a factory rep.
I got my 4 post Direct Lift from Greg Smith Equipment. Great price and service. FWIW
