77GreenMachine
Phillip Talton
- Mar 30, 2010
- Mayodan, NC.
Ok guys saturday I was down by the river in 4low when this terrible binding and popping noise started coming from the front end. This was just normal creeping and turning in sand. On the way out I had to climb a few hills and under a load its real bad and loud as crap! I can feel it when it does it. I thought maybe it was a bad UV joint but after getting a buddy to listen close as I made it pop it seems to be coming from the Tcase. I can spin the front Dshaft back and forth and hear a lot of slack in the chain. Pretty sure its jumping teeth and that's what I hear and feel. I hear the chain even in 2wd now cause its so slack. I gotta fix this before opening weekend. Had it planned for 7-8 months now.
what I need to know is what cases will bolt right in?
mines an NP242 j
assembly #5300 7856
serial#4 4 91 2
Ratio 272
This is in my 91 xj 4.0 Country, automatic .
my buddy has a 231 he said I can have but I need to what all will bolt right in. Last resort is go to pull apart and find an exact match if I can. But it would be nice if the free 231 goes right in. Ill get the numbers and stuff off that case from him later and post that info. Any advice y'all have will help and thanks in advance! And if u got a good case on the cheap let me know.
mines an NP242 j
assembly #5300 7856
serial#4 4 91 2
Ratio 272
