RatLabGuy
- May 18, 2005
- Churchville, MD
Looking at adding a hoist to the garage. Short term for lifting and storing the 4runner top against the ceiling, but longer term that will be elsewhere and I'll likely end up using it for lifting "stuff" around the garage. Likely Bronco top. Ideally pulling an engine from the Bronco but I'm unsrure of the weight distrobution.
which leads to the question... how much is a reasonable load, and what is the bst way to brace it?
it's a 60s Ranch w attached garage, joists are only 2x4s, mounting point would be ~16' in from the door and ~6' from wall along the joists if that matter. Attic has purlins and braces.
Can I get away w/ just running a big steel bar across 4 joists? Would it be better to mount it on the purlins so the pull is at an angle and pushes the weight out?
